x1900gt or 7800gt oc
tpfaff
I can get both of these card for the same price, I'm thinking its a no brainer to go with the 7800gt xxx oc right? The only reason I ask is that the x1900 is new while the 7800 is used!
I would get the X1900GT. Personally, it's a great card and should kill the 7800.
Says the man with a 2900pro:p More opinions are appreciated. Keep in mind its an xxx edition, which i assume means it has higher clocks, also its an oc version, lol so its got uber high clocks?
My mistake its actually a 7800gt xxx ko, does that make a difference?
Is is a 7800GT or a 7800GTX? If it's the GTX, I would go with it, if it's the GT, I would go with the X1900. XXX KO just means that it's overclocked.
i would double check your info man. You are saying that its a 7800 gt xxx ko? XFX is the only company using the xx editions. Evga has somthing similar and they call it the KO version. As for a buying a video. I can tell you from personal experience that trying not to spend too much a video card usually leads to disappointment. Honestly save your $ and get one of these.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2892979&CatId=2669
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150171
You wont be disspointed at the extra $100 when it owns everything you throw at it!
GL! :D
I'm not buying a 320 ever, dx10+high rez=shitty performance.
EDIT: This is the card I was thinking of buying
http://hardforum.com/showthread.php?t=1229742
as you can see in the description it says oc but on the link it says KO, thats why I was confused, err I guess I still am. I am almost certainly going to go for x1900gt later today!
7800GT XXX does not exist. I can not find it at XFX site. And there are absolutely no matches after searching froogle, ebay and pricegrabber. I think he is selling the OC version.
I'd say get this, and if you can handle rebates, then get this.
When I bought my x1900gt, I looked at the x1950gt and some reviews. From what I can remember there were two different gpu's and were clocked differently. The x1900gt outperformed the x1950gt in the benchmarks I looked at. For the price on newegg, I'd get the x1900gt. I'm playing ut3 demo with 40-62 fps at 1280x768 on my crt and cod4 at 70+ fps. I get 150+ with everything maxxed at 1024x768 in CS:S. I've been very happy with it.
The X1950GT overclocks to X1950PRO speeds, which equates the X1900XT. You should also realise the X1950GT is new, while the X1900GT is used.
