x1900 xtx fatality cooler question
Jaquelina
k,
I bought a x1900xtx with fatality cooler from ebay. the problem that I have is that I don't know where to plug the 3 pin power fan cable that's coming out from the video card. just in case, here's the layout of my mobo:
those 2 fan connectors are already being used. what do I have to do to get this video card going? thanks in advance. :)
You'll either need to disconnect one of your system fans(make sure it isn't the CPU fan) to make room for it, or you'll need a 3-pin fan connector to molex adapter which will allow you to connect the fan directly to your PSU.
