Hey guys,
Well I've been building my inventory of machinery so that I can try and start a side business down the road doing machining and fabrication. A week or so ago I picked up a small CNC Mill so that I can make some custom parts for vehicles, computers, etc. I'm working on some small engraving projects (like control panels with engraved letters above the switches) and recently I decided to look into machining a heatsink from T6061 aluminum. Thus far my mill is not up and running yet as I'm still waiting on the servos, but I hope to be machining parts via CNC by the middle of this month.
Anyhow I designed a replacement PWM heatsink for the X1900. It's my first part I've drawn to scale, modeled and created the CNC tool path. With that said it should fit like a glove. It's not super fancy, but then again it's functional. To cut this part I have to do it in two machining operations. One does the bottom of the heatsink and the other does the top. The stock heatsink is 3.67x.28x.5 or there abouts. My replacement is 3.67x.80x1.
Hopefully it will drop the temps on my X1900XTX a bit. What do you guys think?
http://www.dmwtech.com/gallery2/v/machining/ (X1900 album)
I also picked up a much larger mill that I'll be CNC enabling in the coming months:
http://www.dmwtech.com/gallery2/v/welding/machines/mill/
This machine will be able to do some pretty heavy cuts.
