X1800XT PE Flash issues
Digital Viper-X-
Well I have a REALLY weird problem i mean its just weird
when I open the flashing problem
my windows screen gets defunked 0.0 i get artifacts everywhere, before I even try to flash it
not sure whats going on any input? or working links to the ati flash tool?
plywood99 said:
Drop your clocks to 500/500 using ati tool before you flash...
I love you! totaly forgot someone mentioned this before, fixed the problem
thats wierd
2d curruption = teh bad flashed now and going to under go testing =)
9834!! just with flashed havent tried going higher =) this card is great just loud > < gonna pick up a zalman for it
thanks for teh tip it really helped
