yeah... umm heat output... who gives a crap the card is NOWHERE near hot enough to damage itself. noise... speakers or headphones are louder than the card (dont try to say they arent i have a X1900 that I set to spin up to 80-100% in games... its not loud enough to be annoying during gaming unless your TRYING to make NV look better by nitpicking uninportant factors like size instead of IQ, with headphones you cant hear it). X1800's have software adjustable voltage no need for a risky hard mod and can hit 750 mhz on air, they also have High Quality AF, and HDR+AA capabilities oh yeah its only 270 dollars http://www.newegg.com/Product/Product.asp?Item=N82E16814102698 ... and 30 dollars CHEAPER than the CHEAPEST non available 7900 GT... I honestly fail to see how people can recommend the 7900's over their X1K counterpart.Graham_h said:7900gt, runs cooler and quieter. with a very simple 1.4v volt mod, core runs at 670mhz![]()
Rabid Badger said:Thanks for the input, guys. Especially CaiNaM and Stereophile. I think I'm going to go with the x1800xt, it seems to be the better all-around performer, and since I play my games with hi-fi earphones a little whining at high temps won't bother me, and the new ATI 3200 motherboard chipset seems to be pretty awesome. Of course, if I get that, I'll eventually have to get a second x1800xt, just because I can. No wonder I'm always broke.![]()
mxrider131 said:you might want to check out this in depth review. graphics card review
I'm no expert but it seems according to the results on that review the Geforce 7900 gt xxx is the best bang for your buck.
CaiNaM said:i'm sure you'll be happy with it. and i think most of us here feel the same way about "always broke"
oh.. btw, spend a couple extra bucks and get the 512mb version.
