X1800XT for my rig?
Vs17
I was trying to figure out some upgrades for my current rig (in my sig), in which the motherboard is lacking PCI-E, I saw this card and hear the reviews and was leaning twoards it. Money is not really an issue, I'd like to stay under 350 for my video card. Also I was wondering if there was a PCI-E card or adapter that I can buy for my current mobo or if I would need to buy a whole new motherboard... Are there any other graphics cards that anyone suggests? Also I was thinking about adding another gig of ram...
You will need a new motherboard with a PCIE slot(s) if you want to use a PCIE video card. (unless the card is compatible with a PCIE-AGP bridge, which I dont believe any of the mid range or top end cards are, or is even practical or possible.)
So youre choices are basically
(1) Upgrade to an AGP card
or
(2) Upgrade the mobo and get a PCIE card.
Whichever method you choose, remember you will need an extra slot for the top end cards as they are dual slot, and you _may_ need to upgrade to a PSU with higher amps on the 12V rail.
As for choices there are a few 'agp video card recommendation' threads right now, usually the 6800 and x800 agp cards get mentioned in those.
