Andross182 said:with the x1800xt overclocks breaking the 10k mark in 3dmark05 i think its forgivable that the master cards arent on the market yet...just for a refrence, my 7800GT SLI setup stock clocks 425/1025 get me around 10k to 10500, overclocked to 495/1.18 i get 12700 so i think the card has a great score for being a single card
Lord_Exodia said:It's true that the X1800 card gives 10k in 3dmark 05 with overclocking but unfortunately I dont think it makes up for the Master card being unavailable. This is the problem with the Crossfire architecture. The cable in the back is not that bad. The lack of connector on the card for the extra bandwidth to be offset is killing ATI right now. .
Asian Dub Foundation said:yeah i think ATI can't do the whole "SLI connector" sort of thing cause nvidia patent it
I think you have the limitations of the X800 series cards in Crossfire as the X1800 do not have the same limitations. And for the record, it has nothing to do with bandwidth or Crossfire itself, it is a limitation of the composite chip on the X800 series only.Lord_Exodia said:It's true that the X1800 card gives 10k in 3dmark 05 with overclocking but unfortunately I dont think it makes up for the Master card being unavailable. This is the problem with the Crossfire architecture. The cable in the back is not that bad. The lack of connector on the card for the extra bandwidth to be offset is killing ATI right now. Because of this now you have to pay for a Overpriced Crossfire Card and wait desperately for it to come out. Now as far as scoring in 3dmark if that is what you like then that's cool but a X1800 can't give you the real world gameplay that a 7800GT SLI would. I prefer to run games at more playable FPS than to have a high benchmark score (no offense) I also prefer to be able to buy 2 similar cards and link them up then to be left high and dry knowing that whenever ATI decides, I can have my dual card setup. I'm sorry it's this way for you guys but I mean it is what it is.
R1ckCa1n said:I think you have the limitations of the X800 series cards in Crossfire as the X1800 do not have the same limitations. And for the record, it has nothing to do with bandwidth or Crossfire itself, it is a limitation of the composite chip on the X800 series only.
Lord_Exodia said:Sorry Rick your wrong. If there is no link between the 2 cards all of the data will have to pass through the PCIe bus.
Here is a quote from BrentJustice
"bandwidth
you need fast communication between the cards, since ATI does not have a fast internal connector like NVIDIA they had to go the dongle route on the outside, with the idea of no X1300 or X1600 master cards all the communication is handled through the PCI-Express bus, there is no dongle
we already knew X1300 wouldn't need mastercards, their performance is such that all that is needed is the PCIe bus
what's new here is that apparently ATI thinks the PCIe bus is sufficient for the X1600 series as well
but for the X1800 series there is no way they could only use the PCIe bus, they need the dongle because there is just too much of a bandwidth demand
this is all very interesting, could raise the benefit of a 2 x16 PCIe solution on X1600 cards"
Andross182 said:thats not a master card, we have the same 3 part diagram on the x1800xt boxes at CompUSA thats the "crossfire ready" card
Trimlock said:rick is talking about the 60hz refresh rate limited on the x800 cards due to the composit chip, the x1800's do not have this problem, and it is yet to see if the dongle is a good or bad choice with the new ones, seeing as it is currently great for the x800's in terms of performance but poor in their refresh rate
Netrat33 said:Well if the ukoverclockers pre-orders are any indication, you'll see x1800xt mastercards november 21st.
You mis-understood. Neither Nvidia or ATI can run SLI or Crossfire on the PCI-E Bus becuase of bandwidth limitations. Nvidia uses an internal SLi Bridge while ATI uses the external dougle. The external dougle solution is not as good becuase it requires ATi to make master cards. Someone else mentioned ATI should have used an external "box" to combine the images and I have to agree because mastercards were not ATI's best idea. Preformance wise and bandwidth limitations are the same for both ATI and nvidia. Here's to hoping engineers can design the high-end video cards to run without the SLI bridge or external dougle on a DUAL 16x PCI-E mobo.Richards said:Hearing that, if ATI dosent fix that problem of bandwidth that might mean that Nvidia is the only clear gamer performance card at this point, although that remains to be seen with the master cards. Please ATI, pull some ace out of your ass/hat. ( hah I made a joke! )
