I just recently purchased a used X1800 Crossfire card from someone here on the forums. From what i've read, it's basically an X1800XT that can be disabled to work with the XL as well (aside from the outputs, it looks just like the XT).
But when i look at the clocks, it's clocked lower than the XT, and in the Everest utility, it actually shows as an X1800XL
Here are the clocks of the XT - 625 / 1.5ghz
Here are the clocks of my card - 594 / 1.4ghz (i think)
Should i just be able to run the card at XT speeds stock without a problem?
Thanks,
Chris
Thanks,
Chris
