X1600XT or 7600 GS
dogbyte_13
X1600XT or 7600 GS, im on a budget and which chipset would be better for the money? and also what brands should i stay away from? also i just plan on gaming around 1280 x 1024 with some AA or AF maybe, if i hae to i can game at 1024x768 if need be.
that setting is pretty stressful for those cards. especially if its the newer games.
i think the x1600xt would be better no much tho. prob equal.
and there arnt really any BAD brands all the ati ones a good and some nvidia ones have factory overclock cards. and some have better warranties than others.
what is ur budget? cuz u might have to up it .
At that resolution and those settings, the minimum I would reccomend would be a 7600GT or an X1800GTO. You'd be much safer with an X1800XT, X1900GT, 7900GT or the up and coming 7900GS.
dogbyte_13 said:
ok what about at 1024x768 gaming??
Go with the x1600xt It's really not that bad a card. @ 1024x768 it'd be a better bet than the gs I think
i still think u need some more muscle unless u dont mind playing medium to low settings then ull be fine.
i have an x1400 in my laptop and it works good medium to low. heck i play fear medium to low pretty smooth
wow that x1600 in that review overclocked like a mutha. Even more reason to get one, in fact if they are still around for 100bucks I may upgrade my fiances rig. She has a 3500+ with a gig of ram and a x600 (got the card for free). She plays the sims 2 and black and white 2. An x1600xt would probably kick ass in B&W2 compared to her x600xt right?
The cards are so close that I think it just comes down to what you can get at the time and for what price. Both of them should just get by on 1024x768 with some options ticked and a bit of AA/AF. Just remember that for 1280x1024, you most likely will have to kick it up a notch in terms of investment.
FWIW, I'm playing FEAR:Combat at 800x600 with 4xAA on a Radeon X1600XT, and get very good framerate. Looks great.
