X1600, X1800 gpu client
/me has been waiting on the same thing.
More the 1600/1650 stuff than the 1800 though.
can nVidia cards use the GPU client? I've found no definitive answer so just a quick one here, I read the 8800 can but have heard nothing on the 7x00 series.
Im using it but I dont know how to check my times. :p
I think they said the 7xxx series doesnt have enough pipelines or something.
Not at this time. The 7x00 it out of the question from what I have read. The 8800 would be the bare minimum if and when it happens. They are still working on getting things to work on the nvidia cards.
thanks a lot. I folded a few years back and for some reason or another i don't remember exactly but I stopped, but now i've come back to putting in whatever i can on this machine because it's a great cause and i'll be sure to install the client on my computers at home when i'm there.
I've got an x1800 to try it on, but it happens to be in my [H]Bowl boxen and I reallly don't want to mess with it unless I have a bye week !
RPhArrow
You need to look in the FAHlog.txt file.
As it uses a different file format EMIII cannot monitor it.
Points per Day = 4,752 / Frame time in mins.
Mines 4,752 / 5.97 = 796 PpD ....... :D
Luck .............. :D
Someone...anyone? Info on x16xx cards would be helpful to me in the next few hours.
[01:17:55] *------------------------------*
[01:17:55] Folding@Home GPU Core - Beta
[01:17:55] Version 0.10 (Mon Oct 30 12:32:17 PST 2006)
[01:17:55]
[01:17:55] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 13.10.3077 for 80x86
[01:17:55] Build host: CYGWIN_NT-5.1 vishal-gpu 1.5.19(0.150/4/2) 2006-01-20 13:28 i686 Cygwin
[01:17:55] Preparing to commence simulation
[01:17:55] - Looking at optimizations...
[01:17:55] - Files status OK
[01:17:55] - Expanded 82346 -> 443709 (decompressed 538.8 percent)
[01:17:55]
[01:17:55] Project: 2732 (Run 4, Clone 37, Gen 0)
[01:17:55]
[01:17:55] Assembly optimizations on if available.
[01:17:55] Entering M.D.
[01:18:01] Will resume from checkpoint file
[01:18:08] Working on 1258 GPUlambda
[01:18:09] Starting GUI Server
[01:18:09] Resuming from checkpoint
[01:18:09] Verified work/wudata_08.log
[01:18:09] Verified work/wudata_08.edr
[01:18:09] Verified work/wudata_08.trr
[01:18:10] Verified work/wudata_08.xtc
[01:18:10] Completed 24
[01:36:08] Completed 25
[01:52:07] Completed 26
[02:09:46] Completed 27
[02:27:48] Completed 28
[02:44:14] Completed 29
[03:00:17] Completed 30
[03:16:35] Completed 31
[03:32:36] Completed 32
[03:48:38] Completed 33
[04:04:39] Completed 34
[04:20:41] Completed 35
[04:36:41] Completed 36
[04:52:43] Completed 37
[05:08:44] Completed 38
[05:24:36] Completed 39
[05:40:38] Completed 40
[05:56:40] Completed 41
[06:12:40] Completed 42
[06:28:42] Completed 43
[06:44:43] Completed 44
[07:00:45] Completed 45
[07:16:46] Completed 46
[07:17:44] + Working...
[07:32:48] Completed 47
[07:48:49] Completed 48
[08:04:50] Completed 49
[08:20:51] Completed 50
[08:36:53] Completed 51
[08:52:54] Completed 52
[09:08:55] Completed 53
[09:24:57] Completed 54
[09:40:58] Completed 55
[09:56:59] Completed 56
[10:13:00] Completed 57
[10:29:02] Completed 58
[10:45:03] Completed 59
[11:01:04] Completed 60
[11:17:05] Completed 61
[11:33:07] Completed 62
[11:49:08] Completed 63
[12:05:39] Completed 64
[12:22:41] Completed 65
[12:38:43] Completed 66
[12:54:44] Completed 67
[13:11:37] Completed 68
[13:17:44] + Working...
[13:28:23] Completed 69
[13:45:18] Completed 70
[14:01:19] Completed 71
[14:17:21] Completed 72
[14:33:22] Completed 73
[14:49:24] Completed 74
[15:05:25] Completed 75
[15:21:26] Completed 76
[15:37:28] Completed 77
[15:53:30] Completed 78
[16:09:30] Completed 79
[16:25:32] Completed 80
[16:41:33] Completed 81
[16:57:35] Completed 82
[17:13:36] Completed 83
[17:29:38] Completed 84
[17:45:39] Completed 85
[18:01:40] Completed 86
[18:17:41] Completed 87
[18:33:43] Completed 88
[18:50:04] Completed 89
[19:06:06] Completed 90
[19:17:45] + Working...
[19:22:15] Completed 91
[19:38:32] Completed 92
[19:54:45] Completed 93
[20:10:46] Completed 94
[20:26:48] Completed 95
[20:42:49] Completed 96
[21:00:06] Completed 97
[21:17:57] Completed 98
[21:35:33] Completed 99
[21:53:12] Completed 100
[21:54:12]
[21:54:12] Finished Work Unit:
[21:54:12] - Reading up to 45408 from "work/wudata_08.trr": Read 45408
[21:54:12] - Reading up to 972244 from "work/wudata_08.xtc": Read 972244
[21:54:12] logfile size: 34797
[21:54:12] Leaving Run
[21:54:13] - Writing 1053521 bytes of core data to disk...
[21:54:14] Done: 1053009 -> 1018299 (compressed to 96.7 percent)
[21:54:14] ... Done.
[21:54:14] - Shutting down core
I dont know how to get points from that :confused:
Frame times are 16:02 roughly.
That's 296 PPD (a work unit in 26.6 hours).
Is that the 1800 in your sig? Are you only running the GPU folding client?
Thanks for the info. :)
Yeah it's on my x1800xt. It usually completes a 25000frame wu plus some more in a day.
