Hi all,
Got a quick query for those in the know
A friend just got himself an ATI Radeon X1600Pro 512Mb which doesn't seem to perform very well at all, everything appears to be installed correctly and he's using the latest Cats with Ray Adams Ati Tray Tools rather than CCC.
I know it's only a mid range card but it should be outperforming my 9800Pro 128Mb right? even given CPU differences? (AMD64 4000+ for me, Pentium D of some sort for him, fairly recent, I'll get more details later if needed)
ATT gives the following information on it:
I'm new to PCIe stuff so if there's anything amis please let me know, could the fact that it says 2nd monitor be something to do with it? Or my initial reaction was that he may have a faulty card as all the data I've seen on the x1600Pro says 12 Pipes yet his is detecting only 4, which would definetly impact performance.
Any help will be greatfully recieved,
thanks
Dano.
Display adapter Radeon X1600 Series (0x71C2)
Core Name RV530
SubVendor ATI (1002)
SubDevice 2342
BUS 1
Device 0
Function 0
Base Address 0 D000000C
Base Address 1 00000000
Base Address 2 FDEF0004
Base Address 3 00000000
Bus Type PCI Express
SMARTGART Installed No
Driver Version 06.7
Release Version 8.282-060802a-035179C-ATI
QuadBuffer Stereo Support No
Catalyst Registry Path
System\CurrentControlSet\Control\Video\{736A7452-5758-4002-A719-5BA7F233DD38}\0000
______________________________
Clock Information
BIOS VPU 500.00
Current VPU 499.50
BIOS MEM 405.00
Current MEM 400.50
Radeon PCI configuration space
00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
00 02 10 C2 71 07 00 10 00 00 00 00 03 08 00 80 00
10 0C 00 00 D0 00 00 00 00 04 00 EF FD 00 00 00 00
20 01 EE 00 00 00 00 00 00 00 00 00 00 02 10 42 23
30 00 00 00 00 50 00 00 00 00 00 00 00 12 01 00 00
40 00 00 00 00 00 00 00 00 00 00 00 00 02 10 42 23
50 01 58 02 06 00 00 00 00 10 80 01 00 A0 0F 00 00
60 10 08 00 00 01 0D 00 00 00 00 01 11 00 00 00 00
70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
80 05 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00
90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Hardware Information
Installed memory 512 Mb
Memory Type GDDR3
Memory Width 128 bit
Active Rendering Pipelines 4
ASIC details
Family 62
Emulated Revision 10
Gfx Engine ID 3
Radeon Registers
RADEON_BIOS_0_SCRATCH 00000200
RADEON_BIOS_1_SCRATCH 0100C000
GB_TILE_CONFIG 01410011
HWDREG_00000000 2100126C
HWDREG_00000001 00000001
HWDREG_00000002 00000000
HWDREG_00000003 0000000D
HWDREG_00000004 24000B08
HWDREG_00000005 00000001
HWDREG_00000006 00000000
HWDREG_00000007 0000000D
HWDREG_00000008 00000001
HWDREG_00000009 00000000
HWDREG_0000000A 00010090
HWDREG_0000000B 110FAC8F
HWDREG_0000000C 44221100
HWDREG_0000000D 00073011
HWDREG_0000000E 00000000
HWDREG_0000000F 0F3FF01A
HWDREG_00000010 0F3FF01A
HWDREG_00000011 0F3FF01A
HWDREG_00000012 0F3FF50A
HWDREG_00000013 0F3FF01A
HWDREG_00000014 0F3FF01A
HWDREG_00000015 000000CA
HWDREG_00000016 000001CA
HWDREG_00000017 0000018A
HWDREG_00000018 0000010A
HWDREG_00000019 0000014A
HWDREG_0000001A 0000060A
HWDREG_0000001B 0000040A
HWDREG_0000001C 0000001A
HWDREG_0000001D 00000012
HWDREG_0000001E 00000017
HWDREG_0000001F 00008028
HWDREG_00000020 00000000
Video BIOS Information
Version 009.012.008.002
Part Number 113-A67611-107
Date 2006/02/21 16:09
Vram Type DDR2
Controller Configurations
Controller 0
Active Connections:
-Second Monitor (CRT2) (0) 1152x864x85
Controller 1
Active Connections:
No Active Connections
Displays supported by adapter
0 (1) Monitor (CRT1)
1 (2) Second Monitor (CRT2)
2 (4) TV
3 (8) Digital Flat Panel
4 (16) Component Video Output
EnumDisplays
Display Type 0, Extended Type 1 , Max Resolution 1600x1200
Display Type 0, Extended Type 2 , Max Resolution 1920x1440
Display Type 1, Extended Type 0 , Max Resolution 1024x768
Display Type 3, Extended Type 1 , Max Resolution 2560x1600
Display Type 4, Extended Type 0 , Max Resolution 720x480
thanks
Dano.
