X1300 Vs. 9700 Pro
-=JacKaL=- said:
i believe the 9700pro edges it out by a little bit
Although if I had to choose, I would still get the X1300. It overclocks better and has SM3.0 ect (so it's more futureproof.)
Still be better off with an OC'd 6600. Nvm, they're more expensive for AGP. Well, if you can try and fit it in your budget or find one used......
