X-Viper Case
That's a cheap case and you should buy a PSU elsewhere and then put it in yourself. Same with the LEDs or cold cathodes.
I have that case, its okay. It has hella airflow, but dont plan on modding it at all. Not good for water cooling (too many 8mm's, no 120mm's)
However, it does impress the ladies though :p
Edit: Be careful when removing the front, the 2 clear plastic things are supposed to be there.
