X-tune not recognizing Hanngs G 28
nowwhatnapster
I just picked up my third Hanns G 28" monitor. Black friday deal only $240.
This monitor has been progressing over the years, as I was reading reviews, i Learned about X-tune. Which if you own this monitor you know it has some color issues. I do alot of catalog work and would love to use this program to calibrate my monitors better.
I installed it on my Windows 7 PC 64-bit, and it is not recognizing my monitors. It says that they are incompatible. Which i know is incorrect.
I did some googling, and I think it might have something to do with nvidia drivers. I am using a GTX 260 and the latest CUDA drivers (I fold).
Anyone know how to fix this?
The initial download was not compatible with my I-inc 28", but after i downloaded and installed the X-tune update it worked just fine (but i'm using ATI though). You may want to try the update if you haven't already.
I'm still going to bust out my hardware calibrator though, just have to find it first...
Turns out my old old hanns g is the only one not working. The first one I bought when they were priced at $680. To give you an age refetrence.
I installed the update as you recommended, no luck though.
What hardware calibrator do you use? I've shyed away from them because I do not know that much about them.
