X-QPACK Watercooling Reservoir
Steeeeve
I ordered my blue qpack last night and now I am wondering how I am going to fit a reservoir in there. Swiftech recommends that you put the reservoir at the highest point and I guess this makes sense in a way but if you do that on the qpack with a full atx PSU I don't know if you will have room to run the tubes..Any ideas or anyone know if it will fit?
www.swiftech.com or www.frozencpu.com Both have 5.25" bay reservoirs.
Im going to be using a 3.5" res...they wouldnt make them if they didnt work right ;) I would recommend a Dangerden filliport and a T-Line instead, saves space.
I thought you had to have the reservoir at the highest point...is this not that big of a deal?
when i have used reseviors i have had them low and high without problems.
Jen
what is wrong with attaching it to the back, outside of the case?
nothing I suppose...i'd rather have it inside though. I think you put it high so the water wont run out of the radiator or blocks into the lower reservoir...not too sure though.
How about useing a 3.5" Res and mounting it in one of the Hard drive Slots, Or you could mount it on the oppisite sode of the case but you would have to figure out how to mount it. If your useing 2 hard drives then you could mount one in one of the 5 1/4 bays or if your not useing a floppy mount the HD there.
I have been kinda wondering the same thing however I will be useing 2 Lite-On Opticle drives and a floppy, But for now I will only have a single Hard Drive so mounting the 3.5 Res in place of one of the Hard drives will work for me but I will still look to see if I can fairly easily mount it to the other side of the drive cage. I dont have my case yet so I dont know how hard that will be.
Jen said:
building my own micro case
will use a T line , dont see any reason for resevior anymore . take to much room in a case to fit
hugs
Jen
If you mean fill and bleed taps, there is a reason to use reservoir over them (at least according to swiftech, who seem to know their stuff). Swiftech used to use fill and bleed taps in their water cooling kits and they changed to a reservoir a year or so ago. They claimed they could achieve a few degress lower temps using a reservoir (plus its eaiser to fill).
With their new stepped reservoir design they can make a 5.25" reservoir without the problems of airbubbles + cavitation normally associated with shallow reservoirs.
yeah, I am going to test a few things out with the swiffy system... I gotta hot tip on some new Swiftech stuff that is coming out ;) in a little over a week. I plan on buying that stuff and then giving it all a test run.
The new Swiftech parts have been on the front page of the Swiftech website for 2 weeks :p
http://www.swiftnets.com/
To get to the specs page for them you have to click the news links on the right hand side, they haven't added the links to the main product page yet.
They released an entire product range with new pumps\rads\waterblocks. What other new parts could there be? I guess they could make a new reservoir but I doubt that would make too much difference.
