Hey, I've been thinking lately. Stock, the fan with the Aspire X-Qpack blows out, but I've replaced that fan with a really loud 96cfm 120mm fan... anyway, with the fan blowing out it creates a negative pressure inside the case and dust collects pretty quickly, also I have a Zalman 7000ALCU, which blows air down onto the chipset, would it be better to reverse the 120mm fan and have it blow air into the case instead of sucking air out? I think that the Zalman and the fan may be fighting for airflow right now, but I've also removed two PCI cover plates from the back so that it sucks air in that way and that has helped temps a bit. Anyway, has anyone tried reverseing the fan and observing temps before? If the fan blows air in, it'll create a high pressure zone inside the case and the hot air will (hopefully) be forced out thanks to the pressure difference, also this would prevent dust from collecting very quickly inside the case as well. Any ideas on this or am I crazy?
UPDATE: See bottom of thread for my conclusions - In short, having the fan blow OUT is best for temperatures...
