lillimon04
- Oct 24, 2006
my cpu runs kinda too hot for me when the front panel is on, and i always wanted to try water cooling and i love modding stuff, so i was like "watercooling!" lol so now imma try to attempt to put watercooling in a X-GENE mini. i want a 240mm rad, just enough for my cpu(and maybe some overclocking when i get a F-I90hd) and gpu. the loop will be the rad infront, the pump on the left side with a custom built supporting platform so its on the side in the air, then the gpu, then the cpu, the res and then back to the rad. it should look a lil something like this,
. but dont expect this to be build in a few weeks, it will take a couple of months to get the money and then like two weeks to install and do all the modding. i wanna change the front panel so it has an a.c. ryan rad grill built into it or just have the rad grill on the front of the case and no panel. if anyone gots ideas or comments please go right on and give them, please not tooo many bad ones.
parts
rad- swiftech mcr220
cpu block- d-tek fuzion
gpu block- swiftech mcw60
res- Swiftech MCRES-MICRO
pump- either a mcp355 or a mcp655, which ever is better
tubing- 7/16" ID (5/8" OD) Masterkleer General Purpose Clear PVC Tubing
fans- 120mm Yate Loon D12SL
and Petra'sTech "Gel-Stuff" Vibration Absorption Block
a.c. ryan rad grillz stipes
comes out to 333.40. very expensive but worth it
and also lots of help from nonlnear, thanks man
parts
