Because there's no such thing as a perfect SFF case?But looking at the pics, I can't see how that would fit unless you'd cut out the perforated bottom (why is that there in the first place???)
The first would work, but where would you put all your drives? A dual 80mm should work. Putting the rads in bays is not going to accomplish much, because the air is not going anywhere. Looks like you could actually mount an additional 80mm rad on the top front right, in addition to a dual 120mm up front.Well concerning the width issue, i was planning to cut the entire front section out and attach a rad-grill to the front and use some type of C-bracket to do the hard mounting of the rad so as long as the space is there top to bottom i should be good. the other idea would be to do a dual 80mm over the mb but that wont fit because of expansion slot area i think. so i would be left doing 1x120mm/ 1 80mm front with 120 adapter and maybe an 80mm in the top portion but thats gonna be a lot of flow restriction. Ill pose the question over in wc section to see how much rad I need for proposed system.
Not sure if anyone knows the answer to this, but whats the clearance for cpu heatsinks in this case? Its rather tall. Wanted to order one before my case came in.
Thanks in advance.
the clearance is close to 124mm, i didnt add the cpu socket with the cpu. i measured it formthe toop of the mobo(with stand off on) and to the bottom of the top level. u could also cut out the vent holes on the top deck for more room, thats wat i was gonna do, but imma go water coolingNot sure if anyone knows the answer to this, but whats the clearance for cpu heatsinks in this case? Its rather tall. Wanted to order one before my case came in.
Thanks in advance.
