x-fire
crzyhrse50
I have a 4870 crossed with a 4850 for now, How can i get the fan on the 4850 to speed up?
My rig is in the sig. I will be getting another 4870 soon this is a temp set-up.
the fist box shows u how to select the gpu and the other box shows u where to adjust the fan.
P.S. yes that GPU is folding :D
Update, it doesn't work. I set the speed for the 4850 and nothing happened. time to take it out till i get the other 4870. 2 weeks
