Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Question for y'all w/ the x-fi platinum or higher. If you plug headphoens into the front jack, does it auto-change the sound settings to headphone as well as mute the speaker jacks on the back? (I assume there's still an option for the mute)
There are two options you can select. One automatically sets headphone mode when a headphone is detected, and the second option mutes the speakers as well when a headphone is detected.
