X-FI power connector question???
Sipster
I just now noticed that my X-FI Extreme Music sound card has a floppy power connector on it. Am I supposed to be supplying power to my sound card???
if your using the card by itself, then no, if you have the external breakout box then yes, if you have the internal 5.25 bay breakout box then you power the box itself not the card..
Thanks for the quick response. I didn't think I needed it but I had to check.
