X-Fi: Please solve my optical woes
AuxNuke
I did a quick search but i couldn't find my answer. And now for the million dollar question:
Can you hook the new X-Fi up to a set of 5.1 speakers (say some Logitech Z680's) via an optical cable and get 5.1 channel sound in games? Meaning, can the X-Fi decode a games surround sound audio signal and sent it to the speakers via the optical out? OR Is there some way that the X-Fi can send out a 5.1 channel signal and I can use the Z680's built in decoder to have 5.1 channel sound in games? I know with both the Audigy 2 ZS and Audigy 4, this wasn't possible. I HATE having to use antiquated separate analog cables for each channel.
Thanks in advance!
~Aux
X-Fi can decode dolby and dts but if you want 5.1.sound in games this multichannel sound has to be first ENcoded into Dolby. X-Fi can decode or pass thru dolby but does not encode it. Creative has separate device that does that: DTS 610 encoder , I saw it somewhere for $69, can't remember where.
EDIT: you may want to check the review on audioholics They actually note that encoding, with any encoder, introduces latency, so soundwise you may be better off using analog connections, surprisingly.
So I guess the answer is, if it comes encoded from the source (be it games or any other surround source) then the X-Fi or any other Audigy card for that matter can decode it and send the output through the optical cable.
Yet, if the source (mainly games) has seperate 5.1, 6.1, 7.1 streams already "decoded" or sends the streams directly to the respective speaker, you must still use the old analog cables?
Do I have that correct?
~Aux
Your wrong about the Creative encoder, it does not encode in Dolby, it encodes in DTS. DTS is a much better format than Dolby, it does not cutoff frequency response for surround channels like Dolby does.
In order to use the CL DTS encoder, you will have to be sure the device you connect it to can decode DTS.
If the source is already Dolby or DTS, the card can passthru the data to the external decoder via optical (SPDIF). It will NOT be decoded by the card. If it did that, then you would have normal 6-channel uncompressed PCM audio that could only be sent via analog, because it would no longer be encoded.
Current games send out 6-channel PCM streams, which are not encoded/compressed, so yes you would need to use analog
This is why I use the Elite Pro. I let my card do all the decoding, and bass management (which finally works properly for external HT receivers), and just use my receiver as an amp. The DACs on the unit (Cirrus Logic CS4398) are their flagship DACs and are some of the best made. They can be found in hi-end receivers, and studio cards (like the LynxII, which uses the earlier CS4396, which was replaced by the CS4398) Of course, quality components cost more.
