Cliff Couser
- Dec 22, 2003
Just about to order an X-FI Platinum.
having searched and read through this forum...I take it I can't use a standard 40 or 80 pin cable to replace the ribbon cable included in this package.
I'm not about to start drilling as I don't have the skills (or tools) for that.
so...who sells a rounded 40-pin (or the 39 needed for the X-FI)...that can make this minor problem go away?
*For what its worth...the only reason I'm trying to go with a rounded cable is to keep the aesthetics clean in my case. Its all SATA and modular. Also, looking at that ribbon cable, it doesn't look like it will reach the bay from where the card will be.
Thanks!
Thanks!
