Hey guys,
Haven't posted here in ages, but it feels good to be back in the swing of things!
I'm doing a major overhaul on my aging i7-920 build from a few years back. I'm sticking with Intel, and jumped over to a Z87 board.
I'm really excited to make the move, but I have a question for you audiophiles.
I have an older X-Fi PCI board (can't quite recall what the model was, and it's not in front of me currently) which produced great sound and came with a front panel bay that had all sorts of inputs and outputs. Since my motherboard doesn't have a PCI slot, I won't be able to use the card. It served me well, but it's time to move on. Will I notice a difference in sound quality? Is there still purpose in a standalone card? Should I get a Xonar?
My main question, however, is: will I still be able to use my front bay? It uses some sort of ribbon cable that connects to the X-Fi card, and I think it gets its power from a little four or five pin cable from the PSU. Will I be able to get it to speak natively with the motherboard with an adapter of sorts?
Thank you so much in advance.
A
A
