IntelOwnz said:Well here is my future setup:
E6300
Gigabyte DS3
2GB DDR2800
2x WD360ADFD R-0
8800GTS
Just curious if I should buy an X-Fi sound card and use Hardware Acceleration, or should I save myself an extra $100 and just use the onboard audio?
I didn't really see a clear answer in any of those posts?
If you only have a cheap low quality speaker, you can save your money, if you want a better sound, at least buy the XtremeGamer and you will notice the difference on a decent speaker, I don't think it will help you much in performance but you will get an improvement for sound, in games or in musics.IntelOwnz said:Well here is my future setup:
E6300
Gigabyte DS3
2GB DDR2800
2x WD360ADFD R-0
8800GTS
