X-Fi EQ..Missing??
g1xx3r
I just installed the X-Fi XtremeMusic with the drivers from Creative's site(no gui)..Where are the EQ setting.Are they only available with the Gui drivers??
I think you only get it with the complete control panel installation.
If you were installing the drivers for the first time (Or a fresh instal after a format or whatever) you MUST use the CD that came with your card. I just tried reformating my HDD yesterday and installing the newest drivers on Creative's website so I didn't have to update the ones on my CD and such. Well, the audio didn't work. Uninstalling the drivers and using the CD and then upgrading with Creative's website worked perfectly.
Only problem I have had with my X-Fi so far.
Thanx for the replies OK..I guess I should just use the EQ in musicmatch if I dont wanna reinstall the CD stuff..Any other way to get around it??
The EQ in musicmatch is a software eq, the eq in the CL control panel is hardware.
Hmmm..I was afraid of that..Any way to install the EQ w/out the gui??
