Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Sorry, got no real advice for you. What you need is the ability to set different crossovers on different speakers. However the X-Fi can't do that, and if your speakers can't then you are SOL. Any good receiver can do it, but of course a good receiver will cost you more than your speakers, and I don't know that they'd work with it (most computers speakers aren't designed to work with a receiver).
Sounds like a shitty design on their part and there is just little to be done. All channels should be crossed over on any satellite speaker set. Heck it is even a good idea with big speakers. I cross my towers over to my sub at 60Hz.
