Which X-Fi cards share which DAC's? Is there only 1 "top of the line" card out, or do multiple share the dac and maybe just minus panel or outboard connections?
My understanding is that only the Elite Pro uses the "Cirrus Logic digital-to-analog converters with about 116dB SNR". Everything else, including the Fatal1ty versions use the standard DAC.
if im using an extrememusic and have a grado sr325 and hd 595 will i feel the difference if i add an external DAC? like number cruncher or something
Yes, without a doubt. Those are both good cans.
And that's why I can't quite bring myself to upgrade (or whatever) from my Audigy 4 Pro. It's paired with a set of Klipsch ProMedia 2.1 THXs (though I have a set of Logitech X-530s I've been wanting to check out), and as such the only decent upgrade--unless the standard X-Fi DACs work some serious magic--would be to the Elite Pro. And apart from the inevitable driver issues (as in the increasing focus on the current line and the decreasing focus on the previous lines) it's not quite worth it IMHO...can I borrow someone's X-Fi Fatal1ty for a week or two?My understanding is that only the Elite Pro uses the "Cirrus Logic digital-to-analog converters with about 116dB SNR". Everything else, including the Fatal1ty versions use the standard DAC.
The Audigy 4 Pro uses the better DAC too "The main circuit is now stamped Audigy 4, but the changes there seem minor compared to the preceding version. On the other hand, the digital/analog converters have been changed, and that's the main difference between the Audigy 2 and the Audigy 4. Creative has replaced the Cirrus Logic 4382 (8 channels, 114 dB dynamic range) with four CS4398s (2 channels, 120 dB dynamic range). Their design is more professional, and performance has been improved. Naturally, all the capabilities of the Audigy 2 are here too, including the ones supplied by the DSP."
