X-BLADE
XSNiper
Does any body know how to get to the frontmost fan in this case. I need to do some seriously cleaning but need to know how first.
After tracing this case down at Xoxide, and seeing no pictures that would help determine the answer, I'd have to make a wild ass guess that there's either:
1. 4 (possibly 6) screws inside the case that hold the front panel piece on. Usually phillips (cross-tip) head style, you access them by first taking off the side panels, then contorting your hand into an impossible position to get at 'em with a screwdriver
-or-
2. clips that hold the panel on. There are two different ways to get a case front panel off if you have clips like that......either grab it (usually at the bottom), and give it a good jerk, and they'll pop loose, or......take the side panels off the case, then depress the tabs inside the front sides, until the tab slides through the slot.
Pretty much if a case has a plastic front panel, it's attached with one or the other methods. Hope that helps! :D
Ok she's clean. But while this thread is here. I wanna ask, what is the best cathodes? And the coolest looking ones. The one in my case broke, and I can even pull it apart in two. There is also burn marks at each end...
