In case you don't know what an X-Arm is, it is about the coolest mount you can buy for your plasma or LCD. It is motorized and allows you to tilt, swivel, retract to just about any position you want with a touch of the remote. If you never need to adjust your TV, then maybe this is overkill for you. But, if you have a problem with glare, or sometimes need to adjust your TV depending on how many people and where they are sitting and want to find the "sweet spot", this might be for you. You can check out the specs and more details from here:
http://www.closystems.com/
When they introduced it, it retailed for around $2,200. I wanted to wait till price became reasonable. I just found a store on Amazon (search for X-Arm then choose the electronics section) for $714.56 This is by far the lowest price I have seen. Here is the direct link to the store. http://xrl.us/wmiv
