WTF is going on here?
tuaarita
Samsung HD502IJ SATA 7200rpm 16mb
and older HD161HJ SATA 8mb
Basically I'm experiencing extremely slow transfer rate between the two. Copying a 1500mb file from the 161HJ to 502IJ took about 3 minutes which would equal about 7-9 MB/s. Doesn't seem to have a problem reading files but deleting and writing almost locks the whole OS.
Both SATA are running on IDE controller, which I can't seem to change. And yeah then there's the supported UDMA 7 and active UDMA 5.
System in signature.
Could be a OS issue cause the drive diags look fine
