WTB: Sycthe slim 120mm PWM fan
Found what I need.
I am looking for the 120x120x12mm PWM fan (not the 3 pin version) that scythe ships with their Big Shuriken 2 (this http://www.scythe-usa.com/product/cpu/120/scbsk2000_index.html). I've heard that you can arrange to buy this separately, but their support rep told me otherwise.
If anyone bought this heatsink and doesn't need the slim fan let me know.
I have a few Noctua's that I can trade with if anyone is interested; 2x 140mm and 1x 120mm.
Ebay - grandy435
Heat - drown babies
I have one of the 3 pin versions of this, but my MB fan header doesn't do voltage control, only PWM control.
Thanks though.
I bought mine directly from the US distributor/rep, maybe try that?
That used to work, but they closed their US offices, and the rep I contacted said they don't sell it individually anymore.
