Check out swappa - about 700 ish for the 11 pro in mint condition.Bump. Looking for an iPhone 11 pro
Hi folks,
FOR SALE / TRADE:
- Watch Dogs: Legion. $30. requires Geforce Experience + uPlay accounts & RTX GPU. $25 net.
I already have a replacement laptop for the M1 Air, so I'll have to pass.Any interest in trading for my 17” laptop. I’m looking to get an M1 air. I’ll add couple hundred cash.
https://hardforum.com/threads/dell-17-touchscreen-i7-16gb-512gb-ssd-32g-optane-700.2009083/
Did you try right angle power cables? Could fix your case fitment issues and keep the card.
Something like this: https://kareonkables.com/products/evga-dual-inverted-90-degree-to-62-pin-pci-e-cable-adapter
Not recommending that one - that's just a google search but you get the idea.
Was going to offer similar input. After that purchase, last thing I'd want to do is replace the card because of the case.
What about a vertical mount?
Something like this- https://www.newegg.com/phanteks-ph-vgpukt-02-black/p/N82E16811984028
or replace the case? as a last resort. With the current shortage, I'd cherish that card lol.
What if you go vertical mount until you need another pcie slot? Do you see that requirement in the near future? Sorry Just trying to get you to hold on to that card since I'm jealous. I'm still on a gtx980 (non-ti) for the foreseeable future. If it's at least partial buyers remorse, I understand thatIt has 3 power 8 pin connectors, otherwise I would have used a PowerLink or something like what you linked.
I don't really want to go vertical mount yet just in case I need to use another pcie slot on the motherboard.
Could modify the connectors to provide more 90deg bends. Use some liquid electrical tape to insure the connections are secure and insulated from each other. May not be the prettiest but would be functional. Could probably make it look good for that display case you have.
I have the 011-DW with a similar issue with my 3070, I used the vertical mount to solve the issue as well.If you're gonna twist my arm..
Vertical mount bracket should be coming soon. Just like everything else, even vertical GPU mounts are OOS.
Oh well, bump!
I looked in to similar adapters but never ended up pulling the trigger. Now I'm in for 3 of those suckers.I have the 011-DW with a similar issue with my 3070, I used the vertical mount to solve the issue as well.
That said some folks have used three of these to solve the issue (I'm doing both actually, vertical mount and hiding the GPU cables with the adapters):
https://www.amazon.com/gp/product/B07P5R258Q
Here they are in action on a 3080 (they stuck a evga badge on it for accent):
Oh well, bump!
https://discord.gg/BDU4QNZv9E Target is due any day and has been pretty much confirmed just not the day. They drop early AM. Make sure you hit up the role channel and react to the Playstation post to get notified when the stock bot picks up.Bump, will trade (&looking ) for a PS5!
