Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Thanks for all the PM's. I ended up just buying a 1KW coolermaster PS. I bought this one because it had some good reviews and all but the MB connector are the flat type wiring. It makes cable routing easier.
Just as a side note, if you are an active member of this site is there really a question of why anyone would want more than a 1KW supply?
