WTB: Arris SB8200 Cable Modem
bluestang
Looking for an Arris SB8200 DOCSIS 3.1 Cable modem for cheap. Must be in known good condition along with a known good power supply for it.
Reason:
My ISP (Breezeline...formerly WOW! in my area) sucks arse (like most) and can't get their signals right, specifically the upstream causing channels to drop. My plan is 500/50. I had a SB6813 and was having intermittent issues for a while. Recently acquired a SB6190 and installed that as it is still on the recent Approved Equipment list in which they took off the SB6183. Also, bought a new quality 25 FT cable to run from the wall to modem when I swapped in the SB6190.
However, I was still having the same issue on the SB6190 with constant Corrected and Uncorrectables on the modem Status page so it wasn't the modem (SB6183) going bad or something. Had a service tech out to check lines and said they were all good. He cut back cable in house and installed new connector because they had the screw-on type and he put on the good crimp-on. Checked signals and they were all in range. Great...had my 4 channels of upstream back and my D/L and U/L speeds back to normal along with signals levels.
Until last night when it started again with slow internet. Seems my upstream levels are whacked. Corrected and Uncorrectables on the modem Status are back up into the 10's of thousands. I've researched and read that moving to a DOCSIS 3.1 modem may solve the issue, or at least get the ISP to do more to solve the issue. Not sure if there are different signal specs for DOCSIS 3.1 vs 3.0, but I'm willing to cough up a few bucks to prove the ISP is the problem and not something anywhere on my end.
Let me know what you got laying around you are willing to let go for a good price. Shipping will be to 44039 zip. THANKS!
