Wtb: A whole pc system
Svardeked
Hi!
well i may not have the time to build the computer i want to build since i work a lot, so i decided maybe i should buy a whole system
what i want is either an amd 64 system or x2 system. sata is a definite plus. agp or pci-e doesn't really matter. a good graphics card is a plus.
if i don't find anything then maybe i will take the time out of my schedule and try to build my own system.
thanks! my heatware is under Thin Lizzy.
Do you have a budget? I've got two systems right now (opteron 165 / a8n32sli-deluxe / 2gb pc3200 and a Cloverfield core 2 "quadro" / p5b-deluxe / 4gb ddr2 667 ) both in Antec P180s... :)
just copied my post from an other forum
JUST PC 706ATXBK case
550W PSU
Athlon 64 3800+ (never overclocked, runs @ 2.4ghz stock)
ECS KN1-SLI lite motherboard (sli :])
1gb kinston hyperx ram
nvidia geforce 7600 - whips through games no matter what anyone says.
260gb hd (100gb and 160gb)
Legit XP Professional (Its a rarity for whitebox )
Hauppage WinTV-150 pci tv tuner!
Linksys PCI wireless card
NEC 16X Dual Layer DVD burner (amazing dl dvd burner)
Whats a fair price to you?
i have a system, its getting a bit dated. not 64bit...but still performs well.
athlon xp 3200+
asus a7n8x-e deluxe (sweet motherboard)
1 GB buffalo
thermaltake hsf
9600xt 256 (plays bf2 on medium)
200G hdd
nec 16x dvd DL (3500ag i beleive)
enermax 600w noisetaker v 2.0
pro-9 card reader
but cant beat the price....PM Sent
