WSUS
StefanPeeters
Hi everyone,
I'm having an issue where I do not seem to find the solution for. I have set up a WSUS server on 2016 with Windows 10 clients.
The clients in the WSUS al are showing the IP of the router (Mikrotik) instead of the regular IP's. Does someone can explaine me the solution to this issue?
Help is very appreciated!
Thanks
Sounds like your clients that are being routed through the Mikrotik are being NAT'd. Check your NAT policies on the Mikrotik to make sure that's not the case if this is causing an issue. If this is for your organization, check with your network team as there might be a specific reason for this NAT policy.
https://wiki.mikrotik.com/wiki/Manual:IP/Firewall/NAT#Source_NAT
Reactions: djoye
