Guys, I hope someone can help me out. I checked a few threads here and elsewhere, like this one
http://forums.anandtech.com/messageview.aspx?catid=36&threadid=1773709&enterthread=y
but it went over my head pretty fast.
Hopefully I'm not the typical 'help me' n00b. Bought the router (v 1.0 - was this a mistake?? - I checked the linksysinfo.org site first and there wasn't a huge group shouting 'don't do it' over there). Get it home and try to connect my PC to the net through it, DSL connection. No luck - DIAG light is flashing. Manual says update the firmware to thlatest. I try pressing reset button for 30 seconds (both powered down and powered up), nothing. So I go here
http://www.linksysinfo.org/modules.php?name=Forums&file=viewtopic&t=4410
I follow all the steps, dowload the latest firmware update for my specific unit from Linksys, reconfigure my Networking settings, and then I get to this line at the end
Everything smooth up to this point, but... how do I go about doing that? Hmmm.. ok, in the actual upgrade files that I downloaded, there is a Read Me. Aha!
Ok! So I connect my machine to the router via the ethernet cable. Try to enter that 192.168.1.1. in the browser address bar.. nothing. Try http://192.168.1.1., try it without that last period, i.e. 192.168.1.1
Of course I am not connected to the net... I can't connect to the net and have the router connected to my computer at the same time. That's why I am doing this whole procedure.
I unplug the router from my PC and try connecting to the net just to see if that 192.168.1.1 in a browser address bar does something when I am connected. Nope. My internet connection is perfect by the way, working fine this whole time.
Ok... So I go here...
http://www.linksysinfo.org/modules.php?name=Forums&file=viewtopic&t=4428
This tells you how to update your routers firmware. I think that #1 is the way I am trying to do it now. So I decide to try # 2 on this page. I get the tftp program and I install it, connect my router to my computer and run it and it asks me to enter the login and password which I do and then... it tells me that it is not connected to the net!! Login Failed!!
Now... If you read the instructions on this page it says that you must run this app and then it asks you tell it where (in which folder) the firmware update is located and then it will do the rest. But it can't possibly do this unless the router is ethernetted to my PC. And I can't connect to the net while my router is ethernetted to my PC!!
So my problems are
1) Router throws blinking DIAG light, pressing reset for 30 seconds doesn't do anything.
2) Cannot connect to internet through router.
3) Downloaded firmware upgrade but can't get it into the router - entering 192.168.1.1. into a browser address bar does nothing, either connected or disconnected from the net.
Other things. The 'Link' light is not lit on the router, and never has been. However, I can plug the router into my PC and ping it just fine, even though the response times are nothing like the member at Linksysinfo said they should be - he said the pings should be <10 ms and mine are like 750 ms.
The Internet light on the router is solid when I plug it into my DSL modem. I did a search here before posting and there are vague references to problems with older versions of this router and DSL. Anything to that? My cables are known to be working.
Any help is appreciated. Will check in after 2:00 pm EST Saturday.
6. You may now proceed to upgrade the routers firmware with the files that were downloaded.
7. Once the upgrade is complete, the router's red Diag light should no longer be blinking.
1) Before you start, be sure you are using a PC that is connected to the WRT54G
via a wired (Ethernet) connection.
2) Open your web browser (e.g., Internet Explorer, Netscape, etc.)
3) In the Address bar, type in the IP address of your router. The default IP
address is 192.168.1.1.
4) Leave the username blank and enter your password. The default password is "admin",
all lower case.
5) Click on the Administration tab.
6) Click on Firmware Upgrade.
7) Browse for the firmware file that you have just extracted. The file name should end
in .bin
8) Click the Upgrade button.
9) The router will begin its upgrade routine. Do not power off or unplug the router until
the process is completed. This process may take up to 5 minutes to complete.
So my problems are
