Hi I just built my first system with this ram but CPU-Z show timing of 9-9-9-24 and frequency of 654mhz so I changed it to the right timing it worked the first time but after one reboot it came back to 9-9-9-24. Also I tried to put the 1.35v but in the bios I only have option for 1.3 or 1.4 is there a way to override or I should just go for 1.4v.
So were did I go wrong for the timing to be resetted and is there some other parameter I should change manually in the ram setting also is the 666mhz frequencies normal ?
By the way I red the sticky and I'm still not sure of the answers.
