wrong bios settings
r3m3dy
i just built my computer and when i start it up i see that it says my processor is a fx25 while in reality it is a fx57. how do i correct this and also what other settings may be wrong and how can i fix these? thanks for the help.
another question i have is what i should do next. should i install my os or should i format my hard drives(i have 2 and i don't want to make them raid). i am just not sure what to do next.
my floppy drive is only connected by and fdd cable because i couldn't find any thing that would fit on the power suppy part of it. could this be the problem i am having?
Monitor--Dell UltraSharp 2405FPW
Motherboard--DFI LANPARTY nF4 SLI-DR
CPU--AMD Athlon 64 FX57 San Diego 1GHz FSB 1MB L2 Cache Socket 939
Video Card(2)--XFX PVT70FUNF7 Geforce 7800GTX 256MB 256-bit GDDR3 VIVO PCI Express x16
Case-- Thermaltake Armor VA8000SWA
Floppy Disk--SONY Black Internal Floppy Drive Model MPF920 Black – OEM
Memory(2x1gb)-- OCZ 2GB (2 x 1GB) 184-Pin DDR SDRAM Unbuffered DDR 400 (PC 3200) Dual Channel Platinum
PSU--PC Power & Cooling 510 SLI-PFC ATX12V 510W
HD--Western Digital Raptor WD740GD 74GB Serial ATA 10,000RPM
HD-- Maxtor Maxline III 7L250S0 250GB Serial ATA 7200RPM Hard Drive w/16MB Buffer
Media--PLEXTOR Black 16X DVD+R 8X DVD+RW 8X DVD+R DL 16X DVD-R 4X DVD-RW 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2M Cache IDE
