write protection on an usb key annoying...
ar09
i am trying to install "dos" on my usb key but i cant because it says the key is "write protected." how do i disable the write protection???
If a key can be write protected, there's a physical switch on it somewhere.
Had this problem a few days ago. Finally fixed it with the software Repair in the link. Hope it works for you too.
