- Sep 24, 2007
I keep getting this message in windows. system is a Celeron D 331 (LGA775 layout), MSI 915P Combo Motherboard, and a 2gig stick of kingston value RAM. system was overclocking, but i've shut the overclock off. last I can recall it happened after I installed bit defender as an anti virus but I'm honestly not sure what this is.
Im going to try this tweak:
the only other thing i can think is that either the hard drive my uncle lent me is bad which i doubt because he had data stored on here with no issues.
the only issue i came up with was unless i formatted in western digital data lifeguard, windows would format it with 33.7 gigs, even though its a 60GB hard drive.
I'll try that registry tweak first i suppose
then i'm going to try and change the IDE cable.
then run memory tests (its a new stick of Kingston RAM, i dont see why this would be giving me a problem but whateverss)
then run HDD tests (again, doubting its the hard drive)
has ANYONE gotten this error before?
another thing, last time it happened (last reinstall, a few days ago), i was copying some files off my 20GB external hard drive to the 60GB, and having issues. dont know if that is the case.
8. The LargeSystemCache Registry tweak and ATI video adapters. One peculiar set of circumstances that has been observed on multiple machines with ATI video adapters and more than 512MB of memory involves the LargeSystemCache registry setting, a DWORD entry found in HKEY_LOCAL_MACHINESYSTEM\CurrentControlSet\Control\Session Manager\Memory
Management. This setting governs the amount of memory set aside by the system
for certain kernel processes. If it's set to 1 (which allegedly improves
performance on systems with more than 512MB of memory), it can cause data
corruption on some systems, and produce the "Delayed Write Failed" error. Try
resetting it to 0 if it's been set.
