Interesting, the 22.2" 3840x2400 Viewsonic VP2290B is only $1863:
http://compuvest.us/ProductDetails.aspx?ProductID=350543
That's not an insane price at all. No idea whether it's VA or IPS, or what input lag it has, so that would be a lot of money to gamble just to find out if it's any good for gaming. In fact, with a resolution and price like that, I'd wonder what's wrong with it that it's so cheap.
I'm confused. So you actually have that high-density monitor? What is the image being displayed on it...?You really need doggie vision to see this stuff at .12 pixel pitch. Image shows a laptop with 1920x1200 17" next to the VP.
This is something like what the resolution would look like. It fits 4 1920x1200 quadrants side by side.
This is assuming you have a pixel pitch close to 0.27mm, i.e. a standard pixel-density monitor like 22" 1680x1050 or 24" 1920x1200, etc.
Of course, the entire picture would be as sharp and contain as much detail as in the inset. But everything would be *that* small.
P.S. I would love to have a monitor like that just to play around with it.
I think once resolution increases, so will the DPI of pictures and images... it's just going to make everything look sharper have the ability for more detail.
As mentioned, it is not suitable for gaming. It is complicated to drive this monitor at the max refresh rate, which is 41hz. The monitor will only accept single link DVI and up to 4 of them. If you only use one DVI you will get 13hz refresh rate. And no, you don't just hook up 4 DVI and call it a day, it's not that simple, and too complicated to get into. It is not suitable for everday usage as the pixel pitch is way too small for everyday reading. The price is 'cheap' since it has been discontinued for several years already.
Newer revisions could, at least with an adapter, take Dual Link DVI - only requiring two cables.
And the 50 ms response time might seem horrendous but the main difference is that this isn't aimed at stupid Joe - they don't have to lie about the specs.
9503-DG5 model has a native refresh rate of 48 Hz, did not come with a video card, but included an external converter box that accepts a dual-link DVI signal and splits it into two single-link signals - one carrying odd pixels and the other even pixels - for the monitor.
The ViewSonic VP2290b-3 is based upon IBM T221 9503-DG5, according to wikipedia.
http://en.wikipedia.org/wiki/T221
I don't know of anyone, or seen any VP that have the '3' suffex, sold with a converter box. Do you realize how much the converter box cost alone if you can even find one? we're talking over $500. Plus that only converts one of the LFH cables, there is still the other to deal with. And that brings us to... your OS. Other than XP (and using Nvidia Spanning mode), you're going to get multiple seperate desktops on the monitor per DVI input. Even the converter box will only reduce this from 2 to one on the one LFH side.
If by now you all are still not convinced enought of the complication and the limited use of the monitor... knock yourselves out and buy one and welcome to the club.![]()
