WOW
hey_moe
Well I went ahead and finally removed my old water system and replaced everything from the tower to the rad. What a hugh difference. My new MB and processor should be here this weekend and I will be doing the last part of the build. I noticed when I removed the old CPU block and took it apart that it had a clot of gue in it.. Even after I removed the gue and cleaned out everything when I tried to blow through it the air just didn't seem as smooth and the chipset block and the new block. I am wondering now if this is one of the reasons I didn't have good water flow. The only thing I have in the water system is distilled water and Nuke. I am going to do what you guys suggested as far as changing the water every 6 months. One of the biggest things I noticed on this set up compaired to the last water system is no matter how high I OC the temps never go above 130 degs using Prime Time... Sensor Properties:
Sensor Type Winbond W83627DHG (ISA 290h)
GPU Sensor Type Analog Devices ADT7473 (NV-I2C 2Eh)
Motherboard Name Asus P5W64 WS Pro / P5WDG2 WS Pro
Chassis Intrusion Detected No
Temperatures:
Motherboard 29 °C (84 °F)
CPU 37 °C (99 °F)
CPU #1 / Core #1 36 °C (97 °F)
CPU #1 / Core #2 36 °C (97 °F)
CPU #1 / Core #3 40 °C (104 °F)
CPU #1 / Core #4 39 °C (102 °F)
I am OCed from 2.8 to 3.4 which is fine for what I want to do. The new processor coming in this weekend is a 3,2 ...should be able to take to either 3.8 to 4.0...I hope.Thanks for all the help and suggestions you guys me and help through my mess...Mike:D
