WoW Players. Need help.
MrFace
Does anyone elses graphics get to the low 20's in FPS near the flight master in Shattrath? It is blowing my mind as to what is causing this anomoly.
What resolution and settings you run at ?
I'm at 1920x1200 everything High, full AF and 2xAA on a 7900GS currently and I think it doesn't drop that much. I'll double check when I'm home though.
I get a minimum of 40 FPS in that area on an 8800GTS 640MB. Everything caps at about 60 FPS. With everything Maxxed to the hilt including AA
But, that's on a fresh clean XP install with nothing but firewall, AV.
Being on undermine, We're also not a Highly populated server, so that may have something to do with it.
Interestingly enough i can run both PTR and Main server at 60+ FPS side by side windowed on my FWP2005
This area has been a problem with me even after upgrading to my E6750 @ 3.4ghz and it's a problem even when nobody is at the FP. It is the most bizarre thing.
trade in your gts for a GT or GTX
It's something coded in the game wrong, not my graphics card. It's this one spot in the game that cripples my system. I can go in a spot with 100 other players and not have this issue, but those 10-15 NPCs ruin my system.
