WoW memory usage and FPS lag
222 1/3 evil
K, since the WoW forums are totally and completly useless, let me explain my issue for those WoWies here :D.
My character is Nojjon on Wildhammer
My specs
MSI 865pe Neo2 Mobo
P4 2.6a
1 gb ram
6800 gt OC
Thermalright xp-90 w/90mm fan
Two 120mm Delta un modded full blast fans, 1 intake, 1 exhaust
In game resolution set at 1280*1024, anything lower on this 21" monitor looks like shit and is unplayable
Since the last two updates to WoW, I have had two issues which combine to one. When I am sitting @ the desktop My commit charge/mem usage is at 135mb. When browsing the web its approx 180 depending on how may firefox windows are open.
When I start WoW the mem usage jumps a little (understandably) and then starts to rise. Within about 25 minutes of playing I check and my mem usage is at 900mb. This is with running no add ons complelty bone stock WoW install. When it hits this I going into combat, cities almost anything I get FPS drops as low as 1 fps for 30-40 seconds at a time.
Now on to things I have done to fix this issue.
1a. Cleaned PC from top to bottom removed all cards/Heatsink, and removed motherboard from case to make sure it was a dust free as possible
1b. Changed in game settings and nvidia settings multiple times all sliders for visual and changed resolutions still looks like ass but still does it.
2. Deleted all WoW visual interface add ons
3. Tried multiple driver sets for my card (each one having done the driver cleaner safe removal method from safe mode)
4. Disabled my overclock totally so I am running stock.
5. Uninstalled WoW, cleaned registery, re-installed wow
6. Format and reinstalled windows, get all current xp updates
7. Tried the registery edit hotfix set forth from MS for one of their updates from april for security that caused some minor issues with Nvidia extensions.
8. With my game is running my cpu sits at 39-40c and my GPU sits at 56c
9. Turn all game and GFX card settings to the lowest quality they will go (looks like ass but still does it)
10. Installed "older" Creative PCI sound card (older aka 2 years) and run onboard sound
11. Uninstalled above mentioned card when no difference was detected.
12. Followed every single step from WoW tech support team (who by the way are totally useless)
13. Set my page file to a "set size of 1000-1000" still didn't fix it.
The last email I got from them said this " As there are no further issues with your system, I will forward this issue on to be investigated further. While I cannot guarantee a response, I can assure you it will be read."
There was also a suggestion to disable Hyperthreading in my bios, but the issue wasn't there until the 1.10 patch from Blizzard.
I shouldn't have to go out and buy more memory when this wasn't an issue even 1 month ago.
BTW EVERY other FPS game I have (Fear, CoD, CoD 2, Doom3, HL2, Stubbs, Gun all of them run smooth as silk at 1280*1024)
All for one game? :eek:
I've never heard of a memory leak in 1.10, but I'm not up to snuff with WoW. Still has to be a bug on their end.
Due to the caching done, it tends to eat memory like none other. The game will cache massive amounts of textures and geometry data in memory, since its a near guaranty you will be going back to that location at some time, and its faster to load those resources from memory rather then the file, the problem is a lot of systems just don't have that much memory, and start thrashing swap. Most don't have any problems when they hit the 2GB range, and I have a ton of addons and running 3GB (no problems, except LUA garbage collection causes hitches, I HATE garbage collecting languages).
FPS doesn't "lag". Lag is a term related to internet connectivity. Also 1GB probably isn't enough for WoW, especially with fairly high graphic settings.
Ok then pardon my ill chosen word, It skips and freezes. Potato, poTATO same thing slighty different technical meaning. Hopefully it was understood.
I mentioned in my first post, it doesnt matter what GFX settings I have my pc at it still does it.
That answered what I suspected, but the issue I don't understand is, it wasn't happening even a month ago and since the newest patch it is.
Thats just a helluva coincidence.
1gb is more than enough for WoW...I run it everything maxxed on 1 gig and it's silky smooth all the time. From what I've seen with my friend's boxes and my own it seems like 768 is the threshold...512mb will get stuttery in crowded areas and on flight paths, but 768 is pretty much fluid everywhere. 1gb is silky smooth.
There's definitely something whacko going on, but I'm not sure if it's WoW's fault or not. I'm not sure what it could be, though.
Id have to agree that 1g does WoW really well. A buddy ingame was only using 512 then went to a simple 6800nu and up'ed his ram to 1g and says its perfectly smooth. Only time he see's some stuttering is when there are LOTSSSSSS of people in one area at a time, but he said its not bad at all and still able to move around and stuff with no problems, so im using the word "some" in a relative way.
I do agree with ya though, the WoW forums are pretty much useless.
I have 2gigs of ram and my wow never uses more than 400-500megs. I'm having the opposite problem as you :p I've tried everything to get it to use more and there's acctually open trouble tickets with bliz to get it fixed. Sucks having loading lag running back and forth between sides of IF.
Yeah, the recent patches were unforgivable. Even with no mods, i'm still holding the same FPS, if not maybe 5-7 less (alot for me since I do raid). It could also server-side too, due to the recent issues.
I have a friend of mine that does play WoW with 2gb and it is sliky smooth (i've seen it), minus the fact the servers like to die alot lol.
