nnnnno it doesn't.
malfunctioning diode.
edit: actually what kinda cooling is that?
Physically impossible. Something is malfunctioning.
What is with all the noobs posting trash like this lately? ZOMG I HAVE BROKEN THE LAWS OF PHYSICS WITH MY NEW COAR-TOO!!!
How is this trash?
And I checked another (Second Machine) poweredge 1900 (same specs) that is in a more confined room its getting 15c so what your saying is all woodcrest 2.0's have bad temp sensors cool thank you for that info![]()
But Liquid Nitrogen would be -300 probably if its at 10c normally...
Got any other programs to check temps, or just take it apart and touch it if its really 10c then it won't burn but of course theres then no cooling so yeah...
uh actually this might be possible, its a cool chip that doesnt generate a lot a heat, and that cooling system in the dell is awesome! it looks freaking sweet. and my cpu is cooler than my room when the case is closed and under load, then when i take the front panel off so the 120mm fan can get more air into the case it drops to the 20's, and this is all in a sff case![]()
uhhh...actually it's not possible unless the ambient temp in the room is at about 40 F then I might believe it (10c* 1.8)+32=50 F, so you are telling me that his processor is running at 50 degrees F...come on people use some common sense.
The eskimos, they are invading!!!room temp was around 50 something degrees when i took the reading off coretemp
50C or 50F. 50F is pretty chilly. Hope you're wearing gloves while you type. Wouldn't want you to catch cold.
MBM5 on my Laptop reports my CPU temp as -20C. Should I believe it?
I cant stop laughing at this thread. Why do some people not see that you simply cannot cool something with room temp air any cooler than the room itself? Please wake up.
I get what your trying to say. Only reason I believed it was cuz it was unusually cold in my area, and i was getting the readings from two seperate machines.. I was just gonna assume it was -/+ a few degrees from core temp
