I don't konw if anyone has mentioned this but make sure your vacuum is grounded staticly or you will be replacing parts. Vacuum cleaners, or at least the ones made for carpet, build up a static charge you may not see it like when you rub your feet across the floor but its there.Cowcaster88 said:You could do what I seem to do bi-yearly, or whenever I open my case to install something new. I vacuume my computer. Hook up the hose and let it suck up that dust and hair. I stick it close to drive and close to the motherboard, and let it do its work.
Then I close the case and walk off with a grin; it's like I've just cleaned house..
chylld said:is that an antec bqe? i have the same case and this is how i solved the dust problem:
Can you get a fan IN the BQE ? I can't , but then again I use 120mm fans. If you put a 120 on the OUTSIDE of the chasis it butts up to the "filter"on the cover. You still have to clean the "filter". And yes tape up all gaps to stop the usb dust. I would also take it apart and clean it ever so often! jeez!!
Disclaimer: The word "filter" is used as loose as an 80's rocker perm.
