Wow, HDD screws seemingly incompatible with case mounting tray
Noctaurus
Antec Sonata, Samsung SATA drive.
The removable tray has holes on the side and rubber grommets were the harddrive would be. The harddrive has three holes on each side, only one of which will align properly with the tray at any time. To top it off, the screws Samsung included are too big to fit through the side holes of the tray.
What should I do?
re-check the holes you are trying to use ... and the case should come with screws ... at least two holes should align with the tray holes for proper mounting ...
the sonata comes with wierd looking screws that go in from the bottom, though the rubber gromets and mound in the bottom of the hard drive. There should be four of them
