D
Deleted member 68403
Guest
This is going to be a long post, so I apologize in advance. I have Comcast as my ISP and I am using a Touchstone DOCSIS 3.0 cable modem hooked into a D-Link 4500GL router with 1.15 firmware installed. About a year ago, I started experiencing random WoW disconnects, where I would d/c once or twice an hour. I had Comcast replace the modem with a RCA modem and that completely fixed the issue, never had a d/c again.
Well 3 months ago, Comcast had some promo going on where if I added their voip service, it would save me $45 a month off my bill, so I decided to do that. Well, they had to replace my reliable RCA modem with a Motorola in order to do the voip. It worked fine for a month, then I started getting random disconnects, about once or twice per hour. I always have vent running, and usually, vent stays up and works fine while WoW disconnects. Although sometimes, as soon as WoW disconnects, I will lose all internet connectivity on my machine and also on my wife's laptop. Interestingly enough, when that happens, the cable modem and the router both still show that they are connected. This only lasts a few seconds from start to finish.
So thinking that the Motorola modem Comcast gave me was bad, I had Comcast come out and replace it with a Touchstone DOCSIS 3.0 modem. My random d/c's continue to happen and if anything, they've gotten worse now. I thought maybe my router might be the culprit, so I bought a Netgear WND3700 over the weekend and gave that a shot. That actually made things much worse. Instead of like 1 - 2 d/c's an hour, I was getting closer to 5-6 d/c's per hour. So I returned it and tried a Linksys/Cisco E3000 router and same thing, 5-6 d/c's per hour. So now I am back to my D-Link 4500 GL router.
At this point, I'm not sure what is causing my issues. I'm going to guess that based on past experiences, I've got a bad modem but I'm wondering if it could be something else too? Maybe my NIC is bad? I've got an Intel NIC on the way from Amazon to test that out and also have Comcast coming out tomorrow to replace the modem. I just really want to get this issue fixed.
Are there any tests I could be running to help me figure out just what exactly is going on?
